Hi everyone,
How to solve a mass balance error in a rate based model for a regenerator column in HYSYS?
Thank you
Posted 19 February 2024 - 11:17 AM
Hi everyone,
Thank you
Posted 21 February 2024 - 09:12 AM
Check the threshold limits for flowrate parameters in any recycles, they will only push forward a fresh flowrate when there is sufficient difference between the values across the recycle.
Reduce the threshold and the recycle will keep the flowrate updated, reducing the discrepancy in your mass balance.
(composition error across the recycle could also influence the mass balance).
Posted 03 March 2024 - 08:19 AM
thank you for your answer, I could finally solve the problem by playing with different parameters in the parameter tab. Especially changing the pressure drop calculation really worked.
Aspen Plus Convergence ErrorStarted by Guest_NavidJon9_* , 29 Apr 2024 |
General Balance Of Energy On Compressors, QuestionStarted by Guest_MumtazDogan_* , 29 Apr 2024 |
Error In Internal PanelStarted by Guest_Mohammad3799_* , 26 Feb 2024 |
Aspen Edr Error Data BaseStarted by Guest_adrich91_* , 31 Jan 2024 |
Vapor Balance Line From Pump Cane VentsStarted by Guest_100RB_* , 03 Jan 2024 |
