Iso 28300 Venting Calculations
iso28300
9 replies to this topic
#1 Mikemak
Mikemak
  • 4 posts
Posted 22 February 2024 - 08:37 AM
Good day all, I am new into this forum, My name is Mike, I require your help with the following topic, you can also point me in the right direction if possible
I am going through ISO28300, on the calculation of maximum flow rates for normal out-breathing, section 4.3.2.2.1, clause b and clause c Which says:
B) For products containing more volatile components or dissolved gases (e.g. Oil spiked with methane), perform a flash calculation and increase the out-breathing venting requirements accordingly
c) For products stored above 40 degC or with a vapour pressure greater than 5,0 kPa increase the out-breathing by the evaporation rate.
However, none of the venting codes mentions how to perform a flashing calculation or how to calculate the evaporation rate. Can anyone please help me with how I can go about solving these two problems?
Thanks in advance
#2 latexman
  • 1,894 posts
Posted 22 February 2024 - 10:10 AM
Flash calculations and evaporation rates are basic Chemical Engineering skills I learned in college. Are you a ChE?
#3 gegio1960
gegio1960
  • 518 posts
Posted 22 February 2024 - 10:14 AM
which is your stored fluid?
#4 breizh
  • 6,942 posts
Posted 22 February 2024 - 05:18 PM
I believe you got the answer above. Add to the fluid movement, the quantity flashed or evaporated.
Do you have access to a simulator to perform flash calculation?
To get a meaningful answer you need to provide data about your fluid and operating conditions, etc.
Your standard is similar to API 521.
#5 gegio1960
gegio1960
  • 518 posts
Posted 23 February 2024 - 02:23 AM
breizh,
api 2000, not 521.
#6 breizh
  • 6,942 posts
Posted 23 February 2024 - 02:31 AM
Yes , You are right.
#7 Mikemak
Mikemak
  • 4 posts
Posted 23 February 2024 - 04:01 AM
Thanks Latex man, I am a mechanical eng.
#8 Mikemak
Mikemak
  • 4 posts
Posted 23 February 2024 - 04:02 AM
Thanks breizh. I will go through the document.
#9 Mikemak
Mikemak
  • 4 posts
Posted 23 February 2024 - 04:03 AM
Hi Gegio, I don't have a fluid yet, I want to understand how I can go about it when I face that situation.
#10 latexman
  • 1,894 posts
Posted 23 February 2024 - 05:19 AM
I recommend the book I learned flash calculations and evaporation rates from, Unit Operations of Chemical Engineering by McCabe and Smith.  I think the more recent editions have other authors; McCabe and Smith have passed on long ago.
