1
Using Vector User Variable In Hysys
hysys vector user variable
#1 Ulbert Zsolt
Ulbert Zsolt
  • 2 posts
Posted 01 March 2024 - 07:47 PM
Hello, I would like to use a vector user variable in Hysys V14. For example, I  prepared the following code to create a vector user variable using stream temperature:
Sub PostExecute()
    Dim hysysuv As HYSYS.InternalRealFlexVariable
    Dim varVals As Variant
    Dim Count As Integer
    Dim myFluid As Object
    On Error GoTo GetOut
    Set myFluid = ActiveObject.DuplicateFluid
    'Linking to wrapper to hysysuv variable
    Set hysysuv = ActiveVariableWrapper.Variable
    'Setting the range
    hysysuv.SetBounds 2,0,0
    'Retrieving an array of values
    varVals = hysysuv.Values
    'Calculating values using stream temperature
    For Count = 0 To 1
            varVals(Count)= Count*myFluid.Temperature
    Next
    'varVals into hysysuv
    hysysuv.SetValues varVals,"C"
    'Retrieving values (using unit Kelvin)
    varVals = hysysuv.GetValues  ("K")
GetOut:
End Sub
I debugged the code and it looks working well, but in the user variable property windows only the <Multidimensional> word is displayed for my multidim user variable (see the attached picture). When I try to send this variable to a spreadsheet object a <empty>  value is only inserted.
Does someone know how I can see the results of a vector variable variable and use its components?
Thank you,
Zsolt
