Outlet Temperautre Of Reboiler
distillation
#1 hysyshunter
hysyshunter
  • 12 posts
Posted 18 March 2024 - 09:12 AM
I just wanted to check that an inlet stream of high pressure steam of 270C and an outlet of 1100C of a reboiler with a duty of 1.5MW is reasonable, ive simulated it and theres no problems, it's just that i dont if the outlet temperature is a bit ridculous
#2 latexman
  • 1,893 posts
Posted 18 March 2024 - 09:35 AM
Your reboiler process is not clear to me as described.  More details = better replies.
A block sketch of the reboiler with inlet and outlet tube side and inlet and outlet shellside streams specified (T's, P's, flowrates) might help me understand better.
#3 Bobby Strain
Posted 18 March 2024 - 04:06 PM
This is not a reboiler! Maybe a boiler?
#4 latexman
  • 1,893 posts
Posted 18 March 2024 - 05:40 PM
You’re probably right, Bobby.
#5 shvet1
shvet1
  • 476 posts
Posted 19 March 2024 - 01:03 AM
Whatever it is boiler or reboiler what does it boil if steam was specified at inlet and outlet both?
It is definitely a superheater!
#6 latexman
  • 1,893 posts
Posted 19 March 2024 - 06:33 AM
Not enough data; let the guessing continue?  OP help us help you please.
#7 shvet1
shvet1
  • 476 posts
Posted 20 March 2024 - 12:17 AM
Let guessing goes on
Critical temperature of water is 374°C while OP has outlet temperature 1100°C. What means it is a heater - it heats up from 270°C to 374°C, then water becomes supercritical and unable to boil! And tadam - and OP generates steam by heating water, not boiling.
Edited by shvet1, 20 March 2024 - 09:26 AM.
