I am working at the concept stage of a project and for several reasons it would be ideal to locate CO2 Removal Membranes between stages of a centrifugal conpressor on a common drive.
The concern I have is complexity around starting up this process… in a ideal world I would have separate drivers so I can start stage 1, then establish on spec gas from the membranes followed by starting stage 2. Stage 2 will discharge into the export pipeline so being on spec is critical.
Some additional info to consider is the membranes will be started under an automatic sequence, which takes some time as it involves warm-up and slowly dropping the permeate pressure in stages. I.e to make this work I’ll need some kind of bypass to at least get the compressor running.
Does anyone have any experience locating a CO2 removal membrane package between two stages of a compressor with a common driver?
Co2 Removal Membranes Between Compressor Stages
Started by Sinclc, Mar 26 2024 05:03 AM
Feasability Of Downsizing Or Changing Gas Compressor In A Gas PlantStarted by Guest_zbrna_* , 06 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
