Closed Drain System
9 replies to this topic
#1 Falah
Falah
  • 34 posts
Posted 26 March 2024 - 01:19 PM
Dear friends
Greetings
I have a closed drain system composed of
drum and two submersible centrifugal pumps, l asked the contractor to add minimum flow line for the pumps , but they refused. They said that since pumps start when liquid level in drain drum is high and stop when they liquid level is low, there is no need for the minimum flow line, in addition that the pumps work intermittently not continuously.
I think we need to minimum flow line even with these justifications.
Edited by Falah, 26 March 2024 - 01:19 PM.
#2 latexman
  • 1,933 posts
Posted 26 March 2024 - 01:39 PM
What is the design flow rate of the sump pump?  Will the flow be above minimum flow at high level/pump on and at low level/pump off?
I don't think I've ever seen a sump with submersible pump that had a minimum flow line in my 45 years in the chemical industry.  Maybe others have.
#3 breizh
  • 7,062 posts
Posted 26 March 2024 - 05:31 PM
Agree with Latexman and your contractor. The cooling is done by the liquid surrounding the pump.
Share with us some info about the pump .
#4 shvet1
shvet1
  • 476 posts
Posted 27 March 2024 - 11:33 PM
Any pump installation is able to overheated. This threat comes from a point where the liquid is pumped to, not from one where it is pumped out.
Tell us more how you are going to use these pumps.
Edited by shvet1, 27 March 2024 - 11:33 PM.
#5 _1angelia23
_1angelia23
  • 41 posts
Posted 28 March 2024 - 02:17 PM
l've seen many, as in link below for instance
https://we.tl/t-THCdxi7XU9
furthermore does it make sense for pump working not continously and  when high level in drain vessel to work less than minimum flow ? i dont think so
#6 latexman
  • 1,933 posts
Posted 28 March 2024 - 02:37 PM
I cannot access your link.
Attached File  link does not work.png   126.11KB   0 downloads
#7 _1angelia23
_1angelia23
  • 41 posts
Posted 28 March 2024 - 02:57 PM
try this
https://ibb.co/bbpbF5X
#8 latexman
  • 1,933 posts
Posted 28 March 2024 - 03:14 PM
try this
Sorry, no.
Attached File  link does not work.png   129.77KB   0 downloads
Update.  My work laptop is heavily protected by our IT.  I can access your link on my iPhone.  I see the minimum flow orifice on the two sump pumps.  How big (flow) are those sump pumps?
#9 fallah
  • 5,026 posts
Posted 02 April 2024 - 01:38 PM
Dear friends
Greetings
Pump minimum flow line, as general, is a facility for pump protection against pump discharge blockage and its requirement doesn't depend on type of pump operation (continuous/intermittent).
In many intermittent pumping systems in which the pump(s) is manually operated by operator and the pumping period isn't too long, the minimum flow line isn't required; but if the pump(s) is automatically started/stopped the minimum flow line may be required.
#10 Falah
Falah
  • 34 posts
Posted 05 April 2024 - 01:25 AM
Dear friends
Greetings
Thank you, Fallah
