I have a question. If I want to cool a hot gas stream with particulate (like syngas) at T1 to a certain temperature (T2) by direct-contact with water, how do I count the amount of water I need?
Hot Gas Stream Cooling
Started by kaisar, Nov 28 2006 10:22 PM
Posted 28 November 2006 - 10:22 PM
Posted 29 November 2006 - 08:19 AM
kaisar,
Unless I'm missing something, a simple energy balance will do it. The energy contained by your entering dirty gas stream + the energy of water you spray into the gas will equal the energy of the wet, dirty gas leaving the contactor. Knowing the final energy, you can get the mix temperature. (I'm assuming good mixing and an all vapor outlet.)
HTH,
Doug
HTH,
Doug
Missing Data For Stream ComponentsStarted by Guest_Desmith475_* , 07 Aug 2025 |
Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
How To Remove The Condensate In A Wet Gas StreamStarted by Guest_ksagarzazu_* , 25 Feb 2025 |
What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Condenser Inlet Stream TemperatureStarted by Guest_Sampath123_* , 06 Jul 2024 |
