Chemical Cabinet Door
murray
#1 pitret
pitret
Posted 23 April 2024 - 01:12 AM
Everything’s lined up—no frills or fake shit. Just buffer-free streaming that gets straight to the good parts. You know what I mean: those juicy scenes that have you gripping harder than a last-round knock-out.
Toss in a couple of easy search tags like ‘throbbing,’ ‘wet,’ ‘hardcore’ to pinpoint exactly what tickles your fancy without faffing about. Got a specific refinement in mind? These platforms are tweaking their features constantly to throw hotter, more explicit clippings at your eyeballs.
Edited by pitret, 10 September 2024 - 03:05 AM.
  • 1,609 posts
Posted 23 April 2024 - 06:50 AM
If it were me, I would consider a metal cabinet typical for garages with no special seals. With an air-tight cabinet, where will the fumes go when you open the door to get the good stuff inside? Consider a small exhaust fan with a duct to the outdoors if required. A personal computer fan does not take much power at all. Activated charcoal can be used to absorb hydrocarbon fumes. Put some charcoal in the path of a fan inside the cabinet to circulate fumes through it. It might be sufficient to put odor absorber inside - maybe charcoal briquets or kitty litter. Consider finding the leaking containers to repackage or dispose of. Perhaps put each in a large zip-seal storage bag made for storing frozen foods. Perhaps keep a small fan running in the garage to help circulate air. When I play with my garage chemicals, I open the garage door to get good ventilation since I don't want to breathe the stuff either.
#3 breizh
  • 6,887 posts
Posted 23 April 2024 - 07:26 AM
Not a good idea to store chemicals in a Garage! Safety (spillage, fire, ingestion) and Insurance concerns.
https://www.google.c...JPCcTFM&vssid=l
#4 latexman
  • 1,874 posts
Posted 23 April 2024 - 08:13 AM
Have you looked for a used, proper chemical storage cabinet?  Like on Ebay?  You might get lucky.  Then, think about ventilating it.
As breizh says, chemical storage in garage is not ideal.  Minimize all you can.  Properly dispose when you are done.  I only store 1 can of gasoline and 1 can of gasoline/oil mix for my lawn maintenance equipment.
Do you have a carbureted classic car?  Yep, those sure do smell.  My wife complained a lot about mine:
Attached File  1969 Mach 1.jpg   101.46KB   1 downloads
#5 shvet1
shvet1
  • 476 posts
Posted 24 April 2024 - 11:59 PM
Why do you need a chemical resistant door seals? Are you going to put chemicals on the doors. If you are afraid of vapors, then it is enough to close the bottles/containers plugs.
