Hello everyone,
I am confused about pump control in a closed loop (Hot oil Loop). I have attached a snapshot of the system. Is it correct to provide a control valve downsteam a pump in a closed loop ? each heat exchanger has it's own flow control valve. so do we need to add a control valve downstream the pump? Please suggest me what can i improve in this system.
Thank You
