Maintenance And Power Consumption
maintenance air cooler power motor heat transfer process engineering opex
#1 Lyne
Lyne
  • 60 posts
Posted 04 May 2024 - 06:14 AM
Hello everyone,
In an air cooler, What's the relationship between motor power and maintenance suitability. Example, an ACHE with 22 kw motors and one with 125kw motor. The one with 22kw is more suitable for maintenance but why ??
Thank you
#2 latexman
  • 1,928 posts
Posted 04 May 2024 - 06:32 AM
What is your definition of "maintenance suitability"?
#3 breizh
  • 7,058 posts
Posted 04 May 2024 - 07:08 AM
Take a look at this doc for power consumption.
Air cooler (outside) should be cleaned time to time to remove dirt, dust and other contaminants to recover heat transfer area.
#4 Lyne
Lyne
  • 60 posts
Posted 04 May 2024 - 08:27 AM
I found that motors larger than 37.3 kw require gears which incur additional expenses.
#5 breizh
  • 7,058 posts
Posted 05 May 2024 - 03:49 AM
another resource.
Talk to your mechanical dept. about drive, your job is about defining the thermal design and issuing a specification note for quote.
my view.
