At present we are having 3-stage vacuum system in VDU column. We are planning to install a recycle ejector in parallel to the system so that the motive fluid can be used as stripping steam of the vacuum column in place of the existing separate superheated LP steam which will reduce the effective steam consumption & improve the energy efficiency. I need help to calculate preliminary sizing of the ejector & any related paper for better understanding. Thanks in advance.
Recycle Ejector In Vacuum Column
Started by , Dec 01 2006 10:17 PM
Posted 01 December 2006 - 10:17 PM
Posted 06 December 2006 - 12:47 PM
If you go to the GEA website ( http://www.geajet.de ), you'll find a good technical resource, which is at http://www.niro.de/j...me-produkte.htm
They will be able to help you with sizing your system.
