Air Humidity Properties
#1 alaasleem2026
alaasleem2026
  • 14 posts
Posted 19 July 2024 - 01:37 AM
Peace for you
I working on alalysis the air entering 3 stage centrifugal compressor..
Humidity air analysis i get stack when try to calculate properties like enthlpy and density higher temperature from 360 k at high pressure from 3 bar
I wounder if there is a limitation for water vapor in air
I am lookforward any articles or paper which explain the behavoir of water vapor in air at higher P, T
Thank you for reading
  • 6,940 posts
Posted 19 July 2024 - 04:05 PM
Check this document, you may find what you are looking for.
#3 alaasleem2026
alaasleem2026
  • 14 posts
Posted 20 July 2024 - 09:51 AM
Thank you Breizh
i read this file but i still not satisified
all i am doing is build model for compression process in ZH1000 3 stage centrifugal compressor
i get stuck at calculations like when i try solving Specfic Work Done Per stage for Discharge Preasure
i try to find any expemental  work on this like why cant treat with Water Vapor on Air at Higher Pressure and Higher Temperature
and if we cant Exceed those limit ...is possible to lower the accurcy by treating  with dry air  instead of Humidty Air and get the all properties Corresponding to Dry air
Can anyone direct me to similar study like this !
thank you for reading
