Two Phase Analysis For Liquid Oxgen Tank
7 replies to this topic
#1 alaasleem2026
alaasleem2026
  • 14 posts
Posted 22 August 2024 - 05:36 PM
Please for you engineers
I have 45ton vertical tank to store oxygen in liquid phase but not equipped with tonage meter
I try to calc the tonage inside tank
I look forward to any guideline for give approximately solution
Thank you for reading
Edited by alaasleem2026, 22 August 2024 - 06:56 PM.
  • 7,058 posts
Posted 22 August 2024 - 05:38 PM
Share a Pid for us to be able to support.
https://www.engineer...ure-d_2082.html
#3 shvet1
shvet1
  • 476 posts
Posted 22 August 2024 - 11:18 PM
Describe a level meter
#4 alaasleem2026
alaasleem2026
  • 14 posts
Posted 25 August 2024 - 04:46 PM
I mean any mathematical model to use total pressure of tank, geometry of tank and some losses of vented
To give approximately indication of tonnage
Edited by alaasleem2026, 25 August 2024 - 04:49 PM.
#5 breizh
  • 7,058 posts
Posted 25 August 2024 - 06:45 PM   Best Answer
alaasleem2026,
You should have a level transmitter on your storage tank, right?
You should have a Pressure indicator on the top of the ST, right?
You should have a Temperature sensor on the top, right?
You know the total volume of the tank, right?
Basis for calculation:
Mass = Mass liquid +Mass gas
No losses.
density for gas and liquid at T, P available using NIST web site. Google NIST saturation properties
Volume gas =total volume-volume liquid
mass gas =volume gas * gas density
Volume of liquid= section of the tank* height of liquid.
mass of liquid = volume of liquid * density of liquid,
I let you the math (simple)- You may want to use an excel sheet to perform the calculation.
#6 carlos infante
carlos infante
  • 32 posts
Posted 26 August 2024 - 11:04 AM
It is not possible to do.. Oxygen tank is a liquid-vapor equilibrium, under stable conditions it will keep pressure and temperature.รง
Tour company shall provided a leven measurement. Is a safety requirement.
Carlos
#7 breizh
  • 7,058 posts
Posted 26 August 2024 - 09:38 PM
Consider this document to support:
https://files.charti...CS_Rev_B_ws.pdf
#8 alaasleem2026
alaasleem2026
  • 14 posts
Posted 27 August 2024 - 07:42 PM
alaasleem2026,
No losses.
Thank you Breizh i will take steps for that
