Rotated Triangular Tube Layout Vs Triangular Tube Layout
#1 Heat Transfer Novice
Posted 28 September 2024 - 01:35 PM
Why does rotated Triangular 60 degree pitch has less bundle crossflow flow velocity? Is it due to the inline arrangement of tube with respect to flow?
  • 1,635 posts
Posted 28 September 2024 - 07:54 PM
Rotated triangular pitch has an easier path with fewer barriers for the cross flow. It is also more susceptible to vibration problems. The heat transfer is often very little different from exchangers using triangular pitch. If you have vertical cut baffles, the rotated triangular pitch may allow more tubes to fit into the shell. When you find a working exchanger design, that is when you can start optimizing.
#3 breizh
  • 6,939 posts
Posted 28 September 2024 - 08:49 PM
Consider these documents to support your work.
https://chemical-eng...rrangement.html
#4 Blenderaso
Blenderaso
Posted 19 April 2025 - 11:45 PM
Since manuscripts are subject to deterioration
#5 breizh
  • 6,939 posts
Posted 20 April 2025 - 06:08 PM
What is your point?
