Pid In Hysys/ Unisim
Started by NnN21, Oct 01 2024 10:14 PM
Posted 01 October 2024 - 10:14 PM
Hi All,
im just wondering about the PID values in hysys/ unisim. Does the PID values in actual controller will respond the same behaviour if we input it in hysys/unisim? considering the same process conditions, valve CV and characteristic?
Posted 01 October 2024 - 10:25 PM
I would say No, depending how the controller is built in each simulator. The only way to confirm is to perform a test.
My 2 cents
Posted 01 October 2024 - 11:46 PM
No
The idea is the user will adjust the PID in the model depending on the actual actuator response.
Edited by shvet1, 01 October 2024 - 11:47 PM.
Unisim SoftwareStarted by Guest_TunTun_* , 15 Oct 2025 |
