Ratio Pressure Drops-Flowrates
Posted 08 November 2024 - 04:30 AM
dP1/dP2=(Q1/Q2)^2
dP: pressure drop
Q: volumetric flowrate
Posted 08 November 2024 - 08:19 AM
Study this material.
Please work like an engineer and provide relevant information to get a proper answer.
Posted 08 November 2024 - 11:06 AM
Hi Breizh,
First of all thanks for the interesting document.
What I want to do is to roughly calculate the increase of pressure drop in a pipe, when I increase the flowrate.
For that, I am asking if it is ok to use the aforementioned ratio to estimate the pressure drop for the higher flowrate.
I hope now my request is clear.
Posted 08 November 2024 - 11:59 AM
Posted 08 November 2024 - 01:40 PM
Edited by panagiotis, 08 November 2024 - 01:40 PM.
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
