Hello everyone,
I was reading some articles and I got confused with the following:
Does the pump curve shows discharge head or differential head?
(Differential head: Head discharge - Head suction)
Posted 11 November 2024 - 02:54 PM
Hello everyone,
Posted 11 November 2024 - 04:40 PM
hi,
difference between discharge and suction head = Hd -Hs
https://www.rotechpu...trifugal-pumps/
Posted 11 November 2024 - 07:43 PM
Hello everyone,
Differential Head
Posted 11 November 2024 - 10:14 PM
another resource
Posted 12 November 2024 - 05:13 AM
Thanks both, I had the same knowledge that it is the differential head. But, I read somewhere that the discharge pressure/head of the pump you can use it directly in the pump curve. I will try to find the source and I will attach it here!
Posted 12 November 2024 - 06:18 AM
Yes, probably at zero flow, which indicates the shut off pressure and confirm the right pump curve choice, if needed.
Posted 12 November 2024 - 07:56 AM
It was not referring to the shut-off.
Posted 28 November 2024 - 04:41 PM
Using the discharge pressure of a pump can provide an 'indicative' idea of where it is operating on its performance curve. A couple of points to note: technically, a pump curve plots "head" on the y-axis (in relation to you first question). Therefore, the discharge pressure is related to the density of the fluid being pumped. You also need to account for both the suction static pressure and the suction losses.
For example, if you measure 2 barg on the pump discharge while pumping methanol, this corresponds to a head of approximately 25 metres. If the methanol tank feeding the pump has a liquid level 2 metres above the pump and there are minimal suction losses, the differential head would be around 23 metres.
Edited by TheChemEng, 28 November 2024 - 05:21 PM.
Heating Medium Psv DischargeStarted by Guest_Dhams_* , 29 Jul 2026 |
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
