Calculator Problems In Pro Ii
pro ii
#1 kraemema
kraemema
Posted 04 January 2025 - 09:27 AM
I have a problem with the calculator function in Pro II. It won't calculate anything anymore in my simulations.
I tried everthing delete the calculator and put it back in. Closed the prorgramm or/and the file and reopened it.
Does anyone has an idea what else I could do?
The structure and the content of the calculator is attached.
Thanks for the help!
  • 1,635 posts
Posted 04 January 2025 - 11:29 AM
Unfortunately, I cannot determine much from the information you provided. I suggest contacting Pro/II tech support. Even if you supposedly have limited access to tech support because of using a student license, they may help you anyway if you are humble and appreciative and the techie is not too busy.
If I were troubleshooting this in person, I might make a copy of the simulation, export it to a keyword file, then import it as a new simulation to see what errors showed. There may just be a corruption in the file that needs a total refresh.
