Hi
please explain about the design of well ESP or SRP pumps? how can i determine the differential pressure? actually, is it in subsurface scope of surface engineering scope?
Posted 05 January 2025 - 02:21 AM
Hi
Posted 08 January 2025 - 06:29 AM
Do you have P&ID for wells that equipped with ESP p[ump?
Posted 08 January 2025 - 08:19 AM
Please, if anyone has any information about the discharge location of the gas separated from ESP rotary gas separator (RSG), provide information
Posted 08 January 2025 - 11:36 PM
You need to talk with your counterpart that manages the reservoir. In my experience, you will be needing Flowing Wellhead Pressure (FWHP) and Shut-in Wellhead Pressure (SIWHP), which has to be sourced from reservoir information.
Working With Old/paper Pump Performance Curves — How Do You Convert AnStarted by Guest_arundhamodharan_* , 23 Aug 2026 |
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
