Improving Safety By Re-Routing Priming Vent Line In Centrifugal Pump H
#1 Srinivas Agastheeswaran
  • 5 posts
Posted 31 January 2025 - 12:58 PM
Hello there,
Currently, we have BB-5 type centrifugal pump handling LPG with ~21 Kg/cm2 at suction end. For priming the pump after any maintenance, 3/4" pipe is connected to pump casing at top in one end and kept in Open to atmosphere at other end ~3m away from pump base. It is kept in open, only for confirming that liquid LPG is filled up inside the pump casing and whenever, the pump priming is carried out, it creates a safety hazard since the LPG is getting vented locally. Connecting the priming line to flare header would be safer but how can we ensure pump is primed with Liquid LPG? Any view glass can be installed as per standard? Please suggest.
#2 shvet1
shvet1
  • 476 posts
Posted 02 February 2025 - 11:30 PM
Now you are wating untill the liquid propane starts pouring out from the vent, correct?
#3 Srinivas Agastheeswaran
  • 5 posts
Posted 06 February 2025 - 08:22 AM
@shvet1
Yes, As the service fluid being LPG, the fire hazard it creates is high.
#4 shvet1
shvet1
  • 476 posts
Posted 06 February 2025 - 11:36 PM
Spilling out the liquid propane a couple meters close to a pump is definitely an unique and contradictory case
In your case there is no simple tips. Find a competent engineering contractor to audit this process site as the whole.
Edited by shvet1, 06 February 2025 - 11:51 PM.
#5 breizh
  • 6,940 posts
Posted 07 February 2025 - 03:20 AM
Did you check with manufacturer how to prime the pump?
You may not have the right technology?
https://www.flowserv...t.download=true
https://www.ebarbero.../bga-2/?lang=en
https://corken.com/w...022/02/z400.pdf
Share with us a PID of your system.
#6 Dacs
Dacs
  • 457 posts
Posted 08 February 2025 - 11:46 PM
Sight glass at the priming line is one solution, although in itself comes with its unique issues.
