How To Replace Existing Reboiler With A Thermosyphon Reboiler In Hysys
#1 tomr91
tomr91
  • 21 posts
Posted 04 February 2025 - 04:21 AM
Hi everyone,
I'm working on a distillation column simulation in HYSYS V12, and I need to replace the current reboiler with a thermosyphon reboiler. However, I'm unsure about the correct setup and parameters to modify.
Currently, the column is using a conventional reboiler, but I want to implement a thermosyphon system to better reflect natural circulation. How should I do it properly?
  • 6,940 posts
Posted 04 February 2025 - 06:07 AM
What type of reboiler are you using right now and what is the application?
Probably you need to study the material attached .
#3 tomr91
tomr91
  • 21 posts
Posted 04 February 2025 - 09:37 AM
Hi Breizh,
We currently used Kettle reboiler in Aspen HYSYS V12, but our costumer uses Thermosiphon reboiler. I want to know if there is a way to replace in HYSYS to Thermosiphon reboiler?
#4 breizh
  • 6,940 posts
Posted 04 February 2025 - 10:37 PM
Sorry I can't help with simulator.
Kettle reboilers and thermosyphon reboilers are different beasts.
