Cross Over Temperature In Countercurrent Heat Exchanger
#1 panoska
panoska
  • 321 posts
Posted 18 February 2025 - 01:55 PM
Hello everyone,
Is it acceptable to have crossover temperature in a countercurrent heat exchanger?
Or we need to change the design of the heat exchanger?
  • 1,633 posts
Posted 18 February 2025 - 07:34 PM
The cold side outlet temperature can be above the hot side outlet temperature in a countercurrent heat exchanger. Is that what you mean by a crossover temperature? When designing, choose the most economical design that meets all the requirements.
#3 breizh
  • 6,924 posts
Posted 18 February 2025 - 08:14 PM
Consider this link:
https://www.cheresou...eat-exchangers/
#4 panoska
panoska
  • 321 posts
Posted 19 February 2025 - 01:44 AM
Pilezar, this is what I mean.
Breizh, I read the discussion. But, I do not agree that temperature cross is desirable.
#5 breizh
  • 6,924 posts
Posted 19 February 2025 - 06:26 AM
hi,
Nobody says it's desirable, just a matter of fact and cost.
https://www.pdhonlin...m371content.pdf
EDIT :
Others posts on the same subject:
in particular the last comment from srfish , the "god" of Heat transfer with a lot of publications
good luck
#6 Falah
Falah
  • 29 posts
Posted 01 March 2025 - 06:11 AM
Hello everyone,
Do you mean temperature cross?
#7 _1angelia23
_1angelia23
  • 41 posts
Posted 08 March 2025 - 07:22 PM
Hello everyone,
The temperature cross is undesirable, particularly for shell and tube exchangers, because the tube surface area is not utilized effectively and hence there is wastage of capital cost. If outlet temperatures form a temperature cross in a multiple tube pass heat exchanger, a lower than desirable LMTD correction factor will occur. A simple way to avoid this is to use more exchanger shells in series. Other engineers suggest that a small temperature cross may be acceptable and may provide a less expensive design than the more complex alternatives. For a E1–2 heat exchanger, the temperature cross occurs around a relatively narrow range of F value about 0.78–0.82. Lower values of F may be taken as an indication that temperature cross will occur.
