Api Calculation In Hysys
#1 phoroogh
phoroogh
  • 5 posts
Posted 22 February 2025 - 03:18 AM
Hi everyone,
I have recently encountered a situation in which API reported by hysys is different from what can be calculated manually. I have a three phase oil stream (gas+oil+water) @ standard conditions (60F and 1 atm).
As you see in the following screenshots, API is reported to be 25. However, by considering the densities of water and oil at that conditions and the formula "API=141.5/SG - 131.5", 12 will be achieved.
I do not know what the problem is. Isn't hysys calculating API according to the formula?
I appreciate your help in advance.
  • Attached File  2.png   80.25KB   0 downloads
  • Attached File  1.png   77.01KB   0 downloads
  • 1,692 posts
Posted 22 February 2025 - 02:07 PM
Perhaps Hysys ignores the water when calculating API(petrol) value. Otherwise, why include 'petrol' in parentheses? Contact the software tech support for definitive answer.
#3 phoroogh
phoroogh
  • 5 posts
Posted 23 February 2025 - 02:40 AM
Thanks for your reply. I ignore the water as well when calculating API manually. In fact, the liquid phase in Hysys only contains oil and I divide its density @ 60F to the density of water (the aqueous phase) @ 60 F to achieve the specific gravity needed for the calculation of API.
