Supercritical Fluid Flowrate - He Tube Rupture
#1 flarewolf
flarewolf
Posted 07 April 2025 - 03:34 AM
Hello
I need to size a PSV for a HE tube rupture case; tube side supercritical CO2 @2038 psig OP, shell side CW @80 psig OP.
I'm using the method outlined in API 520 Annex B to define the tube rupture flowrate, so I need to perform an isentropic flash from tube side P to shell side P, and table all P, T and density values for each P (20 psi steps for each calculation).
How can I perform this operation in hysys?
  • 6,974 posts
Posted 07 April 2025 - 04:12 AM
Consider these resources to support your work.
#3 flarewolf
flarewolf
Posted 07 April 2025 - 04:27 AM
thank you breizh
my issue now is how to extract properties from hysys for the expansion from tube side P to shell side P
#4 latexman
  • 1,902 posts
Posted 07 April 2025 - 08:17 AM
thank you breizh
You cannot use HYSYS to do the isentropic flashes, thus not needing to extract physical properties?  The boundary condition and intermediate condition physical properties should be available once you do the isentropic flashes.
#5 Said Salim
Said Salim
  • 98 posts
Posted 07 April 2025 - 11:09 AM
You can use NIST Web book to get CO2 properties at different conditions
#6 astro
astro
  • 123 posts
Posted 10 November 2025 - 10:32 PM
thank you breizh
Old thread but I've been dealing with this recently.
Not sure precisely what flarewolf is after exactly but the approach that the crew I work with uses Hysys or Unisim to generate a property table that the user designs by selecting streams and parameters to generate a bespoke data table. Once the simulation runs, it populates the table.
Then it's just a simple copy/paste across to a spreadsheet to populate the various properties required to generate an input data set. One approach is to determine theoretical mass flux, G and other parameters to work through the isentropic nozzle mass flux method. Refer API STD 520 Part I, Annex B. B.1 Development of Flow Equations provides a full run down of the method along with a worked example.
The standard has all that you should need. Apologies in advance, I can't share the spreadsheets that I've got that applies the method. They carry corporate IP. No problem for clever people though. API have set it all out for you - just apply standard methodology and good old engineering judgement and you should be fine.
The tricky bit is to select your property package and validate the equation of state (EoS) you're using. CO2 can behave somewhat strangely above the critical point, so as long as you've done your research there, you should be good to go.
Edited by astro, 10 November 2025 - 10:35 PM.
#7 Alpe
Alpe
  • 17 posts
Posted 13 November 2025 - 08:26 AM
I would suggest to read the old posts, for example
http://www.cheresour...ng-temperature/
with Prode for pure CO2 I prefer GERG2008 or Helmholtz models which are quite accurate,
with Aspen probably there is something equivalent...
also make sure to define correctly the area of discharge... (see old posts for details)
