Considering Non-Condensable Gases In Distillation
distillation non-condensable gases purification methanol water binary multicomponent
#1 riwaldron1
riwaldron1
Posted 10 April 2025 - 07:19 AM
Hi all,
I'm designing a distillation column to purify methanol, with the primary components of my feed mixture being methane, carbon dioxide, methanol & water. How do I treat this column considering 2 of the components are non-condensable gases? Can this be treated as a binary mixture and neglect the impacts of CO2 & methane, or should I only consider them in calculations for bubble & dew points (and therefore only in calculations & design of the condenser)? I initially designed it in a similar way to multicomponent distillation however, I'm not sure that's the correct approach considering they're not specifically part of the vapour-liquid mixture.
Any advice would be really appreciated!
Thank you.
#2 latexman
  • 1,932 posts
Posted 10 April 2025 - 08:12 AM
If you have some design latitude, and you may not, a flash of the feed before the distillation column may get most of the non-condensables out of the feed before introducing it to the column. A flash pot could be an alternative to a larger condenser caused by the presence of non-condensables.
#3 riwaldron1
riwaldron1
Posted 10 April 2025 - 08:42 AM
No, there's no flexibility for adding units to change the feed composition. I believe the methane is probably low enough to be considered negligible and vented in the condenser, however I'm concerned there's too high a flowrate of CO2 to treat it in a similar way and I'm not sure how the CO2 changes the approach to the design calculations.
#4 latexman
  • 1,932 posts
Posted 10 April 2025 - 12:10 PM
Do you have access to a simulator with physical properties? HYSYS, Aspen Plus, or ? That, with a good choice of thermo model, would be the most rigorous way. It would be a multi component design, as you said.
#5 shvet1
shvet1
  • 476 posts
Posted 10 April 2025 - 11:35 PM
Can this be treated as a binary mixture and neglect the impacts of CO2 & methane, ... )?
No as CO2 reacts with water and interferes the equilibrium of H2O-MeOH and CH4 affects H2O&MeOH vapor pressure and therefore equilibrium temperature.
CH4 should be treated as Henry's gas
CO2 should be treated as a water-soluble compund CO2+H2O <=> CO3- + H+
If you ignore those the temp-concentration profile of trays will be different.
A tough task to model I should say.
Edited by shvet1, 10 April 2025 - 11:36 PM.
#6 breizh
  • 7,062 posts
Posted 10 April 2025 - 11:41 PM
I believe the answer given by latexman about installing a flash prior to distillation if the best but,
 we have no idea about the composition of the feed stream.
Flash is not necessary a big piece of equipment.
#7 shvet1
shvet1
  • 476 posts
Posted 11 April 2025 - 12:15 AM
MeOH is volatile and toxic. Flash means losses of MeOH with non-condensables and challenges in MeOH dispersing.
Is it a MeOH production or a water stripping? What losses this process is able to tolerate?
Given this is a study task you should identify&compare options and justify your choosed one. Flashing is one of those.
I believe there are a lot of discussions of a preferred H2O-MeOH model and accompanying impurities in the publications. Did you try any search engine before posting?
Edited by shvet1, 11 April 2025 - 01:01 AM.
