Lng Boil Off Gas Compressor Suction Drum
8 replies to this topic
#1 Lyne
Lyne
  • 59 posts
Posted 04 June 2025 - 11:50 AM
Hello, please I need guidance regarding the sizing procedure for an LNG bog compressor drum, I'm doing reverse engineering for LNG plants and I have been stuck on the BOG compressor drum since there is LNG quench coming from the tank, I want to know how the flowrate of the quench LNG is estimated and how the drum is sized ? Also, by evaluating different heat and material balances I noticed that the BOG and LNG quench don’t have the same pressure, so how they are mixed in the drum if they don’t have the same pressure ? Also can the mixing and the drum be modeled using Aspen hysys? Thank you for your guidance
Edited by Lyne, 04 June 2025 - 12:16 PM.
#2 latexman
  • 1,893 posts
Posted 04 June 2025 - 07:14 PM
Why don’t you address the reply to your last post?
https://www.cheresou...y/?fromsearch=1
How can you expect others to answer your questions if you don’t answer theirs ?
Don’t be a leech!
#3 breizh
  • 6,939 posts
Posted 04 June 2025 - 07:23 PM
Consider this link to support your work.
Suc Drums | PDF | Gas Compressor | Drop (Liquid)
Use the search engine in this forum to get more input about separators.
#4 Lyne
Lyne
  • 59 posts
Posted 05 June 2025 - 01:48 AM
Don’t be a leech!
Hi, I just came across your response now, even though the original post was back in March. I wasn't active on the forum for a while, so I didn’t see the notification earlier.
#5 Lyne
Lyne
  • 59 posts
Posted 05 June 2025 - 01:52 AM
Thank you, the difference in this separator is; the gas is quenched with LNG to avoid high temperature when the anti-surge valve is open; there's no cooler downstream the compressor
#6 breizh
  • 6,939 posts
Posted 05 June 2025 - 03:37 AM
Attached a calculation note about Quench tower.
Good luck,
#7 latexman
  • 1,893 posts
Posted 05 June 2025 - 08:40 AM
When deft clay replied to you, I saw you had been inactive for a while, so I messaged him to be sure he realized that he may not get a reply.  Thank you for replying to deft clay.
When one is away from the community for a while, when they come back, they can go to their profile and click "Find content" to review what was going on when they stepped away.
#8 Lyne
Lyne
  • 59 posts
Posted 07 June 2025 - 11:10 AM
Good luck,
Thanks for sharing
#9 Lyne
Lyne
  • 59 posts
Posted 07 June 2025 - 11:11 AM
Thanks for the guidance
