Rupture Disc Failure Well Below Max Pressure
rupture disc pressure failure
#1 vaibhav02
vaibhav02
Posted 02 July 2025 - 04:22 AM
Hi Folks,
I’m troubleshooting a puzzling safety-device failure and would appreciate the community’s insight.
Plant & Duty
  • Unit: Continuous deodoriser for palm oil (7 horizontal vessels, vacuum stripping).
  • Heating medium: HP steam loop (~50 bar g @ 240 – 260 °C) from a natural-circulation boiler.
  • Rupture disc: REMBE BT-KUB-1, DN25, Inconel®, rated 95 bar g @ 298 °C (batch 2202109). Installed upstream of the safety valve on the boiler outlet; vent stub rises ~4 m, then to atmosphere.
  • Transmitter: 54 PI 240 (0 – 100 bar g, 1 s scan rate).
Failure history
Date Operating pressure when disc burst Expected burst Notes 22 Jun 2025 20.6 bar g 95 bar g Header temp 189 °C; no PI spike recorded. Dec 2024 (similar case) ≈ 25 bar g 95 bar g Same disc model & location.
Trend data show repeated shutdown sequences where pressure falls to the transmitter’s low cut-off (≈ 0.3 bar g) for 6 – 18 h, then ramps slowly back to 60 – 70 bar g during startup.
Two hypotheses
  1. Vacuum-induced low-cycle fatigue
    • During cooldown the closed steam circuit pulls near-full vacuum (transmitter can’t read below 0 bar g).
    • The reverse-acting dome flexes inward; next startup reverses the load to +70 bar g.
    • After a dozen cycles the burst point drifts down to ~20 bar g and the disc finally opens.
    • Evidence: identical pressure cycles every shutdown; no collateral pipe damage; fracture surface shows beach-marks.
  2. Single water-/steam-hammer spike
    • Condensate in the 4 m vent stub is accelerated by incoming steam, creating a very short 100 + bar pulse that the PI tag misses.
    • The disc ruptures cleanly at the spike, PI plot only captures the 20 bar tail.
    • Evidence: some startup traces show 30–50 bar oscillations; hammer in similar lines has reached 5–10 × design pressure in literature.
My questions to the forum
  1. Have you seen reverse-acting discs derate by >70 % purely from vacuum/pressure cycling? How many cycles did it take?
  2. Can a short hammer pulse really shear a KUB-type disc without leaving dents or pipe-support damage nearby?
Thanks in advance for your thoughts!
  • 6,939 posts
Posted 02 July 2025 - 06:50 AM
1) check with manufacturer the possible scenarios,
2) Corrosion is also a possibility together with cycling and spikes
3) Do you have a PM program in place to check regularly the RD condition?
Note: It seems to me that the PSV pops up, this means you have an upset in your process!
#3 Pilesar
  • 1,635 posts
Posted 02 July 2025 - 11:06 AM
Rupture disks are susceptible to physical damage during installation as well as corrosion. Installing them within a holder helps protect them.
#4 latexman
  • 1,893 posts
Posted 02 July 2025 - 04:06 PM
That is a premium RD that goes into a holder. Agree with breizh, contact the vendor. They are expert at this.
