Triethylene Glycol (Teg) Regeneration System
pic
No replies to this topic
#1 guoyinyanliner
guoyinyanliner
  • 29 posts
Posted 23 July 2025 - 09:15 AM
In the TEG regeneration system, the rich TEG liquid flow rate is 1100 kg/h. In the rectification section of the regeneration column, I used HYSYS to perform the internal design calculations. The liquid rate is 1100 kg/h, and the vapor rate is approximately 50 kg/h. I selected a packing type of Pall rings with a column diameter of 300 mm. However, the operating point after calculation appears abnormal.
My questions are:
Is the 300 mm column diameter appropriate for this operation?
Is HYSYS being too conservative in its internal calculations?
If I proceed with a 300 mm column in actual operation, what problems might occur?
Will it affect the separation efficiency?
