How To Model The Bitumen In Aspen Plus?
bitumen modeling
7 replies to this topic
#1 engrbab01
engrbab01
  • 4 posts
Posted 28 July 2025 - 07:09 AM
I am working on a study project of asphalt production process modeling in Aspen Plus. I am struggling to model the bitumen as component. Can anyone could help me.
Thanx
Bab
  • 1,637 posts
Posted 28 July 2025 - 06:13 PM
What do you want to model? Component mass flow only? Stream viscosity and density? What is your list of components and what unit ops? Bitumen should have insignificant vapor pressure. You might can get away with choosing a heavy component that has no vapor pressure and making necessary modifications to its properties. I have used cholesterol in some models for mass balance purposes because of its extremely low vapor pressure without being a solid. If you need properties like viscosity and surface tension then you may have to choose a very heavy petro component or range of components. Is this a student project? Do you have a process flowsheet?
#3 breizh
  • 6,940 posts
Posted 28 July 2025 - 08:53 PM
You may find pointers in this link:
Prediction Of Density And Viscosity Of Bitumen Using The Peng-Robinson - Industrial Professionals - Cheresources.com Community
#4 engrbab01
engrbab01
  • 4 posts
Posted 29 July 2025 - 03:49 AM
Actually I have to model the asphalt production process for that purpose I'm struggling to add bitumen and other components in Aspen Plus.:-(
#5 latexman
  • 1,894 posts
Posted 29 July 2025 - 04:01 AM
Why did you only answer Pilesar’s first question? He had more questions and suggestions. Don’t you want help?
#6 engrbab01
engrbab01
  • 4 posts
Posted 29 July 2025 - 07:16 AM
Extremely sorry for not answering the whole question.
Yes its a study project.
Basically its a project on electrification of asphalt production from fossil fuels to electricity. Please see the attached figure I have to perform mass and energy balance for the system.
#7 engrbab01
engrbab01
  • 4 posts
Posted 29 July 2025 - 07:23 AM
I already attached the PFD but its not shown up. Attaching again to this hopefully this will work.
#8 latexman
  • 1,894 posts
Posted 29 July 2025 - 01:37 PM
@engrbab01,
I see no attachment.
If you edit one of your posts to add the PFD, click "More Reply Options", or if you ever start a new topic and need to add a PDF, click "Use Full Editor".  Either way, then look under the text box.  The file attaching functionality is under the text box.
Or, is there a different issue?
