Design Of Direct Contact After Cooler (Dcac) For Air Separation Unit
#1 Paulogeorge
Paulogeorge
Posted 29 July 2025 - 03:15 AM
Hello everyone,
I am a chemical engineering student currently in an internship with a company in air gases market.
My mission is to troubleshoot and design a new Direct Contact After Cooler (DCAC) for Air Separation Unit.
In effect a hot air stream is being cooled directly using cooled water.
I want to ask if anyone can help me with needed steps how to design the structured packing column; Equations or available papers for public, identitcal work made before or anything can help
and if I have HETP how can I calculate the number of stages to make a simulation in aspen+ or hysys
The attached pdf made by Koch Glitsch contains informations about different packings
the used structured packing will be : Packing from Koch Glitsch : FLEXIPAC 2Y STRUCTURED PACKING IN POLYPROPYLENE OR FLEXIPAC 500Z HC STRUCTURED PACKING IN PFA
Thanks in advance
  • 6,940 posts
Posted 29 July 2025 - 07:34 AM
Get a copy of Perry's chemical engineers' handbook to support your work.
Check at your Uni or in the facility where you are currently working.
(PDF) DIRECT CONTACT AIR-WATER HEAT TRANSFER IN A COLUMN WITH STRUCTURED PACKING
267, 49, 0
#3 Paulogeorge
Paulogeorge
Posted 29 July 2025 - 12:42 PM
267, 49, 0
Thank you very much Mr Breizh, I appreciate that
#4 breizh
  • 6,940 posts
Posted 29 July 2025 - 08:31 PM   Best Answer
other document.
Microsoft Word - 76sola-cervera.docx
#5 breizh
  • 6,940 posts
Posted 30 July 2025 - 12:45 AM
To attach file, click on More reply option (Bottom right), select your document and attach it.
plastic-packing-and-column-internals.pdf
#6 latexman
  • 1,894 posts
Posted 30 July 2025 - 05:09 AM
I'm sorry, I did not realize initially that an attachment was missing.  To supplement what breizh wrote, below is a copy of what I just told another community member.
If you edit one of your posts to add the PFD, click "More Reply Options", or if you start a new post to add the PDF, click "Use Full Editor".  Either way, then look under the text box.  The file attaching functionality is under the text box.
