Hi
How can the pressure profile downstream of a rupture disc discharging a three-phase fluid into a burn pit be calculated? Is there any software available for this purpose?
Posted Yesterday, 05:37 AM
Hi
Posted Yesterday, 06:16 AM
for two / three phases flow , depending from process, you can try to model the disc with the models adopted for valves (i.e. HEM, HNE etc.), there are several threads in this forum discussing those applications.
Kindly, please edit / correct the title :-)
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
![]() Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
![]() Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
