Positive Displacement Pump
#1 Selvakannan
Selvakannan
  • 3 posts
Posted 31 July 2025 - 07:46 AM
I am come cross the Positive Displacement pump P&ID in my current project. Where the suction line design condition are considered as same as discharge design condition. In general for centrifugal pump, up to the suction isolation valve the discharge design conditions will be considered.
Could any one please clarify why the entire suction line is considered as similar to discharge design condition?
#2 latexman
  • 1,894 posts
Posted 31 July 2025 - 09:31 AM
Convenience, less piping specs.
#3 breizh
  • 6,942 posts
Posted 01 August 2025 - 12:16 AM
Should be at least the same size or larger inlet and outlet pump's ports.
Hydraulic calculation is required to optimize the pipe size, cavitation and head loss.
#4 deft clay
deft clay
  • 19 posts
Posted 04 August 2025 - 11:24 AM
Something to consider also is that there are numerous types of PD pumps with different applications and idiosyncrasies. What type does your project use?
In some cases, you need to consider suction and discharge pipe sloping if the pump handles vapor poorly.
#5 Selvakannan
Selvakannan
  • 3 posts
Posted 02 September 2025 - 01:02 AM
Thank you all for your valuable contribution to the discussion.
