2
Is Emergency Venting Required For Polyethylene Storage Tank In Fire Sc
plastic storage tank
#1 chem55
chem55
  • 20 posts
Posted 01 August 2025 - 03:06 PM
I am planning to install a polyethylene storage tank for a chemical that is classified as an oxidizing liquid but not flammable. Nitrogen blanketing is not required for this application. For normal breathing (in and out), I intend to use a gooseneck vent in accordance with API 2000.
My question is: Do I need to consider emergency venting for fire scenarios?
Given that the tank is made of HDPE, I assume that in the event of a fire, the tank would melt rather than build internal pressure. Therefore, I am leaning toward not including an emergency vent. However, I want to ensure this approach aligns with best practices and safety standards.
Any insights or references to applicable codes or standards would be greatly appreciated.
#2 latexman
  • 1,841 posts
Posted 01 August 2025 - 09:02 PM
Just make the gooseneck vent big enough for the hypothetical fire case, and you’ll be covered.
#3 breizh
  • 6,797 posts
Posted 01 August 2025 - 09:12 PM
Consider talking to safety bureau and/or fire department to get appropriate answer.
Why don't you share with us the name of the chemical?
#4 latexman
  • 1,841 posts
Posted 02 August 2025 - 08:11 AM
Bravo!  More details = better answer.
#5 breizh
  • 6,797 posts
Posted 04 August 2025 - 01:15 AM
In case you need to size an emergency vent , you can use the spreadsheet attached.
#6 carlos infante
carlos infante
  • 19 posts
Posted 04 August 2025 - 02:49 PM
Could we mention which is the chemical than you wants to storage??
Carlos
