Missing Data For Stream Components
#1 Desmith475
Desmith475
Posted 07 August 2025 - 06:27 PM
Hello, I'm working on my capstone project and it involves separating pyridine and methylpyridine out of the waste water of a pyridine synthesis process, and I'm having some struggles with simulating it. The goal of the project is to bypass the pyridine-water azeotrope to get 99.75% purity pyridine and it has multiple impurities that also need to be dealt with.
Going off of a paper which proposes an extraction and stripping process for separating pyridine and water, they used n-propyl formate, and an expired patent gave a clue that DMSO might also be a good solvent for this purpose. Unfortunately it is missing information and can't calculate UNIFAC LLE binary coefficients for n-propyl formate, but it can for DMSO. I looked in the "edit properties" menu of the fluid package tab and saw that a few components were missing variables a, b, and c under the tab "gibbs", which seem to be coefficients for a polynomial. Activity coefficient models, as far as I know, exist to model excess gibbs energy so these missing numbers might help me get a better working simulation. I googled around for info along the lines of "gibbs energy polynomial" and "gibbs coefficients" and couldn't find anything that came close to what I was looking for. Is there any literature out there for this specifically I could track down?
Am I just on a wild goose chase? I feel like using simpler models wouldn't be good work for such a highly non-ideal system as this but it may be necessary. Any suggestions for how I might bypass this issue if I can't directly rectify it would be appreciated.
Edited by Desmith475, 07 August 2025 - 06:29 PM.
  • 6,937 posts
Posted 07 August 2025 - 09:28 PM
Check whether IPE (Isopropyl Ether) could work for your system. Other name Diisopropyl ether
cas number
108-20-3
I have experience using this solvent to separate water from organics.
3 columns ,1 ELL column to separate water from organics, 1 stripping column to remove traces of organics from the water prior to discharge to WWT plant where Fenton treatment is taking place, 1 distillation column under vacuum to separate solvent from organics.
The split of organics will require more columns, at least one.
BP pyridine 115C
BP others methyl pyridine between 128C -145 C.
Good luck.
#3 Pilesar
  • 1,635 posts
Posted 07 August 2025 - 09:56 PM
Possibly relevant literature:  Design and Control of a Hybrid Extraction–Distillation System for the Separation of Pyridine and Water | Industrial & Engineering Chemistry Research
