3
Real Or Ideal Cp/cv For Control Valve Calculations
control valve specific heat ratio
#1 sumwunrandom
sumwunrandom
Posted 14 October 2025 - 05:53 PM
Hello fellow Chemical Engineers,
If one is determining a gas breakthrough scenario through an existing control valve with a high dP (such that the flow will be choked), is it more appropriate to use the 'real' Cp/Cv (e.g. calculated by HYSYS) or the 'ideal' Cp/Cv?
I have compared results for both and found that using the 'real' ratio gives a 12 % higher flowrate. For the purpose of my calculation (determining amount of gas breakthrough), the 'real' ratio is more 'conservative'.
I would compare this to PSV sizing in which API 520 notes that 'ideal' ratio should be used as it *typically* results in a more conservative design, and that if you are not careful, using 'real' ratio can result in undersized orifices. I have trawled through Annex B of API520, posts in this forum and ENGTIPS (incl https://www.cheresou...2-psv-sizing/),where caveats to the API 520 statement are mentioned (such as that 'ideal' ratios are not always appropriate for a select few mixtures, or when gas is near critical point). I also note ' Using the ideal gas specific heat ratio for relief-valve sizing"; by Aubry ShackelfordBerwanger, Inc.; Chemical Engineering, November 2003.'
However, I can't seem to find any information anywhere on CONTROL VALVE SIZING specifically. This includes reading through control valve supplier 'technical bulletins' and the such.
Any thoughts?
  • 6,939 posts
Posted 14 October 2025 - 08:08 PM
I believe it's based on ideal. Consider the document attached and annexes.
Probably good to ring valve suppliers.
EDIT: More convenient to use ideal when you don't have access to a simulator.
Note: Make sure you compare apple to apple,
Compare Xt calculated using the ratio K gas /K air at atmospheric conditions for ideal and at process condition for real.
Good luck.
#3 Alpe
Alpe
  • 16 posts
Posted 15 October 2025 - 02:01 AM
MASONEILAN / ISA formulations probably have been empirically defined (and measured),
for example the distinction between a subcritical flow (velocity < speed of sound) and supercritical is based on a value = 0.5 which does not correspond to reality in most cases (accordind some papers the values for the critical pressure ratio in valves can be in the range  0.2 … 0.7).
There are alternatives, for example ISO 6358 etc.
I did similar evaluations with the models for control / safety valves included in PRODE PROPERTIES (see prode.com) and I see differences.
As suggested by Breizh probably with Masoneilan / ISA formulations one should use ideal values and take care of the limits...
