I want to cool hot air of 25000m3/hr at 270C to 250C by adding ambient air at 21C.
Can some one guide me how much dilution air (ambient air) needed to add in hot air?
Posted 02 December 2025 - 11:16 PM
Perform heat and mass balance.
To start let you assume same specific heat capacity or use the link underneath.
Use the perfect law gas to calculate the density of air at (T,P) prior to perform balances or
Air Properties: Temperature, Pressure & Density Data
What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Adding Inlet To Compressor Through Vba (Hysys/unisim)Started by Guest_Matylda_* , 30 Jul 2024 |
Adding Components Through Vba To HysysStarted by Guest_Matylda_* , 26 Jul 2024 |
Ambient TemperatureStarted by Guest_srsh_* , 21 May 2023 |
Impact Of Ambient Temperature And Solar Radiation To A Gas StreamStarted by Guest_Jon K_* , 06 Apr 2023 |
