3
Compressor Selection Based On Flowrate & Compression Ratio
compressor compressor driver
#1 Dhams
Dhams
Posted 19 January 2026 - 03:23 AM
I'm supposed to select the compressor type (Centrifugal/Reciprocating) along with type of Driver (Electric/Gas Turbine Driven) based on the following available data
Flow : 0.6 MMSCMD of Natural Gas
Pressure :  5 to 55 barg & 45 to 90 barg
Based on the compressor selection chart (attached), Multistage Centrifugal Compressor can be selected (If I'm not wrong) & Driver based on Load/Space.
Kindly advise if it is best suitable for the above statement, both technically & financially feasible.
  • 6,942 posts
Posted 19 January 2026 - 04:55 AM
Nothing attached.
Prepare a specification sheet and submit it to vendors.
Select at least 3 vendors per technology to get a realistic budget.
#3 Dhams
Dhams
Posted 19 January 2026 - 06:41 AM
Hi Breizh,
Thank you for the response.
I'm trying to attach the file, meanwhile based on this tread
https://www.cheresou...3854#entry43854
I have took reference for Compressor Selection chart.
#4 breizh
  • 6,942 posts
Posted 19 January 2026 - 07:08 AM
To add a document, use the More Reply Options Button (bottom right) then Choose file button to attach the document selected and then Attach the file (click on the Attach button )
EDIT 1 :
Top 10 CNG Compressor Manufacturers in the World 2025 - PCCS
EDIT 2:
Calculators to support your work
Centrifugal Compressor Performance Calculator
CheCalc ‐ Fluid Flow
