Edited by Sciosophy, 03 March 2026 - 10:26 PM.
Handheld Ethanol Fuel Content Analyzer
Posted 03 March 2026 - 10:25 PM
Posted 03 March 2026 - 10:52 PM
Perhaps some ideas from here: https://copilot.micr...dp2VTeJtp9UWcUn
Posted 04 March 2026 - 01:54 AM
- Water Extraction Method (Field Test): A common, simple method involving adding a known amount of water to a fuel sample in a graduated cylinder. The ethanol binds with the water and separates from the gasoline; the increase in volume of the water layer indicates the percentage of ethanol.
This may be sufficient enough!
Posted 05 March 2026 - 05:08 AM
Disclaimer - I have no experience with measuring ethanol in gasoline but I am familiar with measuring ethanol water mixtures in the beverage industry.
Your biggest problem is going to be in establishing a base line for the gasoline as the range of chemical species that can make up gasoline is very wide. From my limited experience with fuels, the "ethanol" that is used can also contain other alcohols which have similar fuel values but for which the other properties that you are considering can vary as well. This probably means that whichever method you finally decide to use, you are going to have to calibrate your instrument by making up a range of samples and measuring them individually to create a calibration curve for you particular circumstances.
In the beverage industry the most frequently used methods used (outside of specialist laboratories) are density and refractive index. The cheapest way of measuring density is with a hydrometer but this needs a similar sized sample to the water separation test which you are trying to avoid because of the sample volume. There are electronic density meters that vary in price from a few hundred dollars to tens of thousands of dollars. These meters use only a few millilitres of sample.
The densities of ethanol and gasoline do not differ as widely as ethanol and water, so you may have some accuracy issues with using density.
Refractive index might be better from an accuracy perspective, and certainly it requires much smaller samples - typically a few drops. Refractometers vary in price from very cheap for hand help analogue instruments, through to a few hundred dollars for portable electronic units, and right through to the tens of thousands of dollars for lab grade units. Here again you will need to generate your own calibration curves.
Posted 05 March 2026 - 11:03 AM
I think density as a property to get at this will be a non-starter, because you will need to know the density of the starting gasoline feedstock before the ethanol is added. Since this can vary, it will be difficult to impossible to determine ethanol concentration based solely on density.
While I didn't find a lot of technical information on the internet, a quick search suggests that the "flex fuel" sensors in your car are using an electrical property of some sort to measure EtOH content in real time. I'm wondering if an automotive sensor would be a good starting place for a project like this, since an automotive sensor must be able to reliably get EtOH content based solely on the properties of the fuel in the tank (and stored calibration curves).
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
Water Content Of CondensateStarted by Guest__1angelia23_* , 10 Jul 2024 |
Analysis Of Ammonia Content In EthyleneStarted by Guest_Movers_* , 04 Jun 2024 |
Aspen Flare System Analyzer (Training Material)Started by Guest_opel_* , 22 Feb 2016 |
