I'm working in an ethylene plant that has a vessel that takes filtered quench water with boiler feedwater makeup level control and uses a series of high pressure steam fed reboilers to boil the quench / bfw mixture to generate a lower pressure steam which is mixed with the ethane cracking furnace feed. In this plant, the main vessel, all the reboilers and superheater are built to ASME Section VIII and the overpressure protection system is also all compliant with Section VIII code. To me, this system looks like a classic unfired boiler and while the code says the vessels themselves can be built to section VIII, I believe the overpressure protection system must be built to Section I (no block valves unless they are Section I compliant switching valves, 3% overpressure rules, etc...). The low pressure steam runs at about 800 kPag. Am I out to lunch? We are possibly replacing one of the switching valves. The vendor is saying that they have to be Section I because its on steam service period. I don't think that is necessarily the case if the steam PSV wasn't part of a boiler system, but in this case, I believe this to be an unfired boiler which should have Section 1 compliant OPP. Am I out to lunch? Anyone have any experience with these?
Ethylene Plant - Is The Dilution Steam Generation System An "unfir
Started by Alfreedo, Mar 12 2026 02:31 PM
No replies to this topic
Posted 12 March 2026 - 02:31 PM
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Ethylene Oxide Off-SpecStarted by Guest_Movers_* , 25 Feb 2026 |
