Edited by Lyne, 16 March 2026 - 03:15 PM.
Centrifugal Compressor Cmpression Ratio /discharge Temperature Limit
Started by Lyne, Mar 16 2026 03:11 PM
centrifugal compressor discharge temperature pressure ratio
Posted 16 March 2026 - 03:11 PM
Hello, what’s the max compression ratio allowed for centrifugal compressors ? Is a pressure ratio of 6 allowed ? Also what is the discharge temperature limit ?
Posted 20 March 2026 - 02:28 AM
Consider this chart and other docs to support your work.
Compression ratio depends on molecular weight of gas being compressed.
More information better answer.
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
