I’m trying to understand if two dissimilar discharge check valves are required downstream of a single-stage centrifugal compressor. From what I’ve read, reverse flow typically occurs during a compressor trip in case of multistage compressors or parallel trains.
Reverse Flow On Centrifugal Compressor
Started by Lyne, Today, 04:52 AM
centrifugal compressor two dissimlar check valve reverse flow single stage
No replies to this topic
Posted Today, 04:52 AM
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
