Dear friends,
I'm familiar with Packed Tower designing more or less and before this I was sure that Acid stripping towers were another kind of packed towers.but when I used the same method which I use in design a common sulfuric acid packed towers, the results are so different with an example stripping tower which we have in our project. I'll appreciate if you tell me more about stripping tower designing and the probable differences that they may have with other packed Towers.
Thanks.
Stripping Tower
Started by Guest_asad_*, Jan 14 2007 11:16 AM
Guest_asad_*
Posted 14 January 2007 - 11:16 AM
Posted 15 January 2007 - 02:03 PM
Asad:
The general design of packed towers hinges on the unit operation of mass transfer. The types of mass transfer usually applied using packed towers are:
1. Separation of a liquid mixture – distillation;
2. Separation of a gaseous or light component – Stripping;
3. Absorption of a specific gaseous component from a gas mixture – absorption;
4. Saturation of a gaseous stream with a liquid component – contactor, humidifier;
5. Sensible cooling of a gaseous stream with a cool liquid – quenching;
6. Sensible cooling and absorption of a gas mixture stream – Scrubbing;
The above are just some of many uses for packed towers. You don’t state exactly or specifically what you intend to do in your “Acid stripping tower”, so we can’t really be sure whether this is a proper application for a packed tower. You also don’t share the exact, different results you obtained in your “design”. Therefore, once again, we’re stopped short in trying to understand what it is you are trying to design.
You also don’t state what type of design you mean. Is it a process design or a mechanical design. I have to assume you mean a process design. Stripping towers are commonly used in stripping Unit Operations. Applications such as stripping CO2 out of an Amine solution are very common in industry. Stripping of a light solvent (such as THF) from a heavier solution is also a common use.
Basically, there are little – if any – differences in a packed Stripper as compared with other packed towers – such as scrubbers, absorbers, and distillation columns. All these mentioned towers bring about a mass transfer and any differences between them would be subtle – such as random packing or structured packing. One way or another, the packing used brings about the same scope of work.
If you desire more specific responses, you should supply a specific example(s) or applicaition(s).
Guest_asad_*
Posted 16 January 2007 - 05:59 AM
Dear Sir,
Thank you for your attention. the stripping tower which i mentioned before is belong to a sulfuric acid plant case. first of all I should explain that, this plant is exist now and I'm checking it's equipments for Revamping .
the exist SO2 gas in product (93% sulfuric acid) should be seperated from liquid phase before we send it to the storage tanks. when I use "Hess" method for process disigning of this tower the results for Tower diameter , volume and height of packing bed are much less than the values which the designer has considered for the exist stripping tower. I'v used the same method for checking of other packed tower in the plant ( Drying and Absorbing Towers) and the results of calculation is very close to them.
I think the main reason for such a difference might be mass transfer coefficient which I use for this tower.I use the same mass transfer coefficient that I use for other towers, but my manager assured me that safty margin has been considered for those towers and it's correct.
I thought I could check this problem with ASPEN PLUS rating.and i got good result but the problem is I don't know how to undrestand which mass transfer value is used in ASPEN calculation.
anyway I'll appreciate if guide me. I can send You my calculation or any more information if you think is necessary.
Thanks.
Thanks.
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
![]() Absorber Tower Can't Be ConvergedStarted by Guest_dynamichysys_* , 14 Jun 2024 |
