In sizing of a Safety Relief Valve (SRV) reaction force at the outlet is used by piping engineers to design for the support ( normally supplied by the vendor).
For Steam and vapor applications literature exists which determines reaction forces
I am looking for guidance/standard literature for calculating the reaction force at the discharge for a liquid application where the discharge piping is under a superimposed backpressure of 45 psig and has around 50 feet of 1-1/2" piping .
It eventually vents into an tank. So for all purpose it is a closed discharge system
Does the reaction force for the RV gets affected by superimposed back pressure ?
Any help will be much appreciated.
Reaction Force At The Discharge Of Liquid Relief
Started by sahas, Oct 28 2003 05:03 PM
Posted 28 October 2003 - 05:03 PM
Guest_Ben Thayer_*
Posted 14 November 2003 - 03:41 PM
Yes. Superimposed backpressure will impact this. For equations, see API RP520 Part II 4th edn., 1994 2.4.1
They will have an equation for discharge of vapor to atmosphere and give observations on how to complete a calculation for a closed system. With a closed discharge system, there are time related factors to consider for gas systems.
I realize your application is for liquid but the methodology should be similar.
You may want to consult a valve supplier for information on reactive forces also. Anderson Greenwood's sizing software gives reactive force as an output.
Posted 04 March 2004 - 03:01 PM
[FONT=Arial][SIZE=7][COLOR=blue]
In the discharge pipe the force in every direction change is defined by:
F = PA + pAV2/g
P .... pressure
A .... pipe cross-sectional area
p .... fluid density
V .... flow velocity
g .... gravitational constant
During the transient when the valve is opening, the fluid begins to travel trough the pipe displacing the air and the said force acts on every pipe elbow.
When the pipe is completely full of liquid and the flow is continuous, every impact force ( the force produced by the fluid entering the elbow ) is compensated by the corresponding reaction force ( the force produced by the leavig fluid ) and finally only remains the last reactio force.
For example in a valve discharging trough a vertical elbow upward, the only final force will be the reaction vertical down.
F = PA + pAV2/g
P .... pressure
![]() Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
Pressurizing LiquidStarted by Guest_Ahmadhamzahperta_* , 02 Apr 2025 |
