I have recently joined the pharmaceutical company and now I want to check energy efficiency and design of euipments like compressor, boiler, ejector, cooling tower, blower. Can anyone help me in this area. I want the standard procedures.
Design Of Equipments
Started by Mandar, Feb 14 2007 02:13 AM
Posted 14 February 2007 - 02:13 AM
Guest_STEVELEE_*
Posted 17 February 2007 - 03:48 PM
The only standard procedure for determinng equipment efficiency is applying the equation, efficiency = Energy Output/Energy Input and from derived efficiency curves based on percent loading of the equipment. You will need to check with the equipment manufacturing literature to get the efficiency of the units for which you are interested. For example, a boilers efficiency will improve if it is equipped with an economizer and a blowdown heat recovery system. It all depends on the set up and the percent loads of the unit. If you want to get more specific you will need to consult the equipment literature.
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
Performance Testing Of Air Cooled Heat Exchanger In Off Design ConditiStarted by Guest_go-fish_* , 09 Dec 2024 |
