hI,
If a vacuum tank(operating pressure = -0.8K) is designed as Full Vacuum ,IS
a vacuum relief valve still needed (to feed N2 into the tank)?
Thanks,
sfhh
Is Vacuum Relief Valve Needed?
Started by sfhh, Oct 30 2003 09:04 PM
Posted 30 October 2003 - 09:04 PM
Posted 02 November 2003 - 12:51 AM
NO. Vacuum relief is not needed if the vessel is designed for full vacuum.
Guest_Ben Thayer_*
Posted 05 November 2003 - 05:06 PM
We recently had a request from our QA group to do vacuum testing similar to our pressure testing. Since we basically test piping for 1.5 times operating pressure for our Installation Qualification (e.g., test at 150 psig for 100 psig service), they did not understand our chagrin when they asked us to vacuum test to 1.5 times the -14 psig operating pressure or -21 psig.
When I told them we couldn't, I was told I was being uncooperative.
Another reason why I suspect I am not dealing with engineers.
Ben Thayer
Posted 05 November 2003 - 08:04 PM
I wish I had a good come-back for that one!!!
I suspect you are correct, they aren't engineers and probably can't spell the word either.
Posted 10 November 2003 - 11:12 AM
Reminds me of the story of a young Environmental Compliance Officer reviewing wastewater analyses. He came back to the engineer with a complaint. "All the values are close to zero except pH. 7 is too high. You need to reduce pH to zero, too."
Maybe he's working in this QA group now.
![]() Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
