In HYSYS environment whenever you have aqoues phase in your material stream,HYSYS will give you the properties and information of it in a separate column beside the liquid and vapor phases data.Is there any specific reason for that?
Warm Regards.
Cheers.
Aqoues Phase Data In Hysys
Started by jprocess, Feb 21 2007 08:49 AM
Posted 21 February 2007 - 08:49 AM
Posted 21 February 2007 - 10:25 AM
I read your post 3 times an can still not understand your question. If you have 3 phases, wouldn't you want to know the properties of each one of them? Hysys also gives you the bulk properties of the whole stream, if that is what you need.
Posted 21 February 2007 - 08:57 PM
Hi jprocess,
I have same observation as you did. If you look at the aqueous flowrate, it's zero flow. Not quite know what the reasons behind presenting the aqueous properties knowing the flow is zero.
I guess...sometimes when you have 3 phase (GLW) separation and your may want to consider few % aqueous carry over to condensate side. You may simply copy the condensate stream (with aqueous properties) on new stream, manually adjust the aqueoous flow and mix it with condensate stream. This will form the basis for your downstream treatment facilities but without affecting the overall HMB.
Another observation in HYSYS, if the aqueous flow is too low (under-saturated), the aqueous properties will dissappear.
Hope this help
JoeWong
Hope this help
JoeWong
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Missing Data For Stream ComponentsStarted by Guest_Desmith475_* , 07 Aug 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
