Design Of A Gas Plant On Hysys
Started by shanti1927, Feb 25 2007 11:52 AM
9 replies to this topic
Posted 25 February 2007 - 11:52 AM
Hi Friends...Can anyone give me information of an existing gas plant. I need the compostion of the feed, temperature, pressure, flow rate and where the plant exists and some info about the plant. I am designing gas plant on HYSYS.
Thank You
Shanti
Thank You
Shanti
Posted 26 February 2007 - 01:45 PM
Shanti
See the attachment.
See the attachment.
Posted 26 February 2007 - 03:05 PM
Hey Pronab, Thanx a lot for the information, Can you let me know the composition of C1, C2, C3 too ? and name of the gas plant..where it is existing ? I appreciate you for the info given.
Shanti
Shanti
Posted 27 February 2007 - 04:22 AM
Check it and tell us your HYSYS result.
Posted 27 February 2007 - 06:05 PM
Hey Pronab...Thank you very much...Can you tell the name of the plant and where it is located ? I will post HYSYS file once I have done it..
Thank you
Shanti
Thank you
Shanti
Posted 11 March 2007 - 07:10 AM
dear shanti,
in hysys, proii, aspen there is at least one sample file about amine plant.
take care : in all of these simulators use amine property package.
take care : in all of these simulators if you are using MDEA as solvent the amine package can't predict the performance correctly. Prosteam software is a very powerful choice for amine system including MDEA solvent.
very nice design help is in GPSA manual.
regards.
regards.
Posted 12 February 2008 - 03:25 AM
Dear Akhilani,
Can you please let me know from where can I get the Prosteam software for using MDEA as solvnet.
Posted 29 February 2008 - 06:49 AM
I have one concerning HF, including the HYSIS simulation. If you are interested let me know.
agat_ir@hahoo.com
agat_ir@hahoo.com
Posted 29 February 2008 - 08:19 AM
QUOTE (Vishal N Master @ Feb 12 2008, 09:25 AM) <{POST_SNAPBACK}>
Dear Akhilani,
Vishal, ProSim is a predeccesor of ProMAX software developed by Bryan Research and Engineering. It is used to design and optimize gas processing, refining, and chemical facilities. More info at:
http://www.bre.com/promax.aspx
Posted 12 November 2008 - 04:12 PM
QUOTE (Vishal N Master @ Feb 12 2008, 04:25 AM) <{POST_SNAPBACK}>
Dear Akhilani,
Hi
do u have any flowsheet for modeling gas engine on hysis.?
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
