I've been doing tons of research on Fick's Law. I understand how to derive it and what its used for. I just need to see an example of it being used.
I need to use this equation to separate water from an alcohol and aromatic component.
Any help is greatly appreciated.
Fick’s Law
Started by chemeguy, Apr 25 2007 01:13 AM
Posted 25 April 2007 - 01:13 AM
Posted 12 May 2007 - 05:02 AM
Chemeguy,
The law of Adolf Fick is a constitutive one that describes the molecular flux of a chemical specie. It can't be used to separate a mixture of water and alcohol; but plays a role in describing the process that does the separation.
You only need fick's law in separation processes that exploit differences in diffusion rates of various species.
For your system, I suggest you focus on Pervaporation- this is one process that could separate the mixture you have on the basis of diffusion rates.
Posted 02 June 2007 - 02:16 AM
QUOTE (chemeguy @ Apr 25 2007, 01:13 AM) <{POST_SNAPBACK}>
i suggest you to read "the fundamental of momentum heat and mass transfer" by welty, ok
