Reciprocating Pumps' NPSHa
			Posted 05 May 2007 - 12:39 AM
How NPSH for reciprocating pumps should be calculated?
Which diferences exist in calculation in comparison with centrifugal pumps?
Thanks in advance.
Cheers.
			Posted 08 May 2007 - 05:22 AM
If you take some effort "google" it, i am almost certain that you will find your answer...
You may check API 14E for explaination & example.
JoeWong
			Posted 09 May 2007 - 03:57 AM
I checked API 14E totally but I did not find any material regarding to my concern.
Warm Regards.
			Posted 09 May 2007 - 05:28 AM
I am referring to API 14E, 5th Edition, 1991...
Please read section 2.3, part b (page 15) for some explanation...
Please read subsequent page (page 20) for calculation of NPSHa...
Please read example A2,page 50-51 for example...
Hope above help...
JoeWong
			Posted 09 May 2007 - 07:53 AM
Thanks a lot for your guide.
But one question:
As you know the title of this standard is "Recommended Practice for Design and Installation of Offshore Production Platform Piping Systems"
Can I use it for onshore application of reciprocating pumps?
Warm Regards.
			Posted 09 May 2007 - 08:56 AM
I don't think there are any differences from acceleration head / NPSH persepctive......you can confirm my statement by checking any Pump Handbook.
JoeWong
			Posted 09 May 2007 - 09:52 AM
Why make thing so difficult there? don't confused Reciprocating pump NPSH(a) calc with centrifugal pump methodology, both is the same.
 Attached please find Pump sizing spreadsheets and literature. A good article explained NPSH(a) also attached here.
a) Pump sizing - Centrifugal or Reciprocating
 Pump Min flow
 Pump Min flowc) Pump By pass
d) Pump NPSH(a)
e) detailed hydraulic line & pump sizing (Line sizing, pressure losses)
			Posted 12 May 2007 - 12:11 AM
The Npsh calculation as you claim is not the same for reciprocating and centrifugal pumps.The difference is in a term called "acceleration head" that for centrifugal pumps is negligible but for reciprocating pumps you should include it.Just look at the reference that Joe mentioned.
Good Luck
			Posted 14 May 2007 - 11:40 PM
Post # 7 stated that there are some attachments, I cant find any! am I missing some thing.
					#10
			Posted 16 May 2007 - 09:35 AM
I'm not sure why they removed the download link, if you need pump calc / hydraulic line checking / pump literature just give me your email and i will sent it.
regards
					#11
			Posted 16 May 2007 - 10:33 AM
You can also copy me at obioma.osuoha@impac-nigeria.com.
Thank you
Obioma osuoha
					#12
			Posted 20 May 2007 - 12:21 PM
william.novaes@oxiteno.com.br
Thanks and Best Regards.
WSN.
					#13
			Posted 21 May 2007 - 12:18 AM
Please, e-mail me as well.
kebabhouse@gmail.com
Thank you.
					#14
			Posted 22 May 2007 - 11:52 PM
I am an unior engineer, I am trying to set up a speadsheet to check pumps performance. Could you feel free to sent this file to me by email: ntthabh@yahoo.com.vn
Thanks & best regards
					#15
			Posted 23 May 2007 - 04:49 AM
I'm sending out, check your mailbox.
Due to overwhelm response on pump spreadsheet, can you guys wait couple...
I try to upload here but internet too slow lah
also, i got 3.3 MB space only
					#16
			Posted 23 May 2007 - 01:33 PM
					#17
			Posted 23 May 2007 - 01:44 PM
Is there any one who knows how i can link my own model developed in Fortran with PROII by using user added subroutine
If somone have any information let me know at hamid01m213@gmail.com
Hamid
					#18
			Posted 24 May 2007 - 10:01 AM
waiting for your loading files
thanks
					#19
			Posted 24 May 2007 - 07:59 PM
due to overwhelmed responses and i have not time to sent one by one. So i created a link here and you guy and download from here.
a) Centrifugal or Reciprocating pump sizing
 Hydraulic line verifications and pump optimization
 Hydraulic line verifications and pump optimizationc) Pump by pass
d) Pump min flow
e) NPSH
f) Pressure drop by CARF Eng
Item (f) - a quick pressure drop & hydraulic calc from CARF> I strongluy recommended you guys use it to quick estimate pipe fitting loss, pump discharge pressure required. This program is very nice and I use it for many years.
Regards Danny
			Posted 26 May 2007 - 04:00 PM
Hi Friend, Please send these attachments to my email id umeshdesh@yahoo.com
Umesh
					#21
			Posted 26 May 2007 - 10:25 PM
I encourage you to take a little bit of your valuable time to read previous post whithin this subject...You may download directly from the links inside the DTAN76's post (#19)...
BTW, your action should be quick...as i notice there are some copyrighted materials...
JoeWong
					#22
			Posted 28 May 2007 - 12:18 AM
Let's return to the discussion
 We found that npsha for centrifugal pumps is independent of pump type but for reciprocating pump,npsha have dependency to pump type like simplex,doupleax,triplex.etc because the acceleration head should be specified based on pump type which is specified by vendor.So what approach the designer should follow for preliminary calculation?
Thanks in advance.
Cheers.
					#23
			Posted 29 May 2007 - 04:53 AM
Suggest talk to your mechanical engineer and conduct preliminary selection of reciprocating pump.
Hoping other Che Jedi advise some good rules of thumb.
JoeWong
					#24
			Posted 03 October 2007 - 08:56 AM
I also attached the link for your reference.
http://www.wjta.org/...2_De_Santis.pdf
					#25
			Posted 03 October 2007 - 09:06 AM
Why do you require NPSH for reciprocating pumps?
| Pulsation Device In Reciprocating CompressorStarted by Guest_zaidanamir_* , 17 Feb 2025 |
|   Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
|   Restricted Orifice (Ro) After The Reciprocating Compressor? Why?Started by Guest_VolereePotere_* , 24 May 2023 |
|  Answered   Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
|   Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library FAQ
   FAQ Search
   Search FB
