Flowrate Thru Pipings
#1 narseille
narseille
  • 7 posts
Posted 12 December 2003 - 03:45 AM
Please share with the the simplest/basic formula or equations that I can use to calculate flowrates of the following thru pipeworks:
(i) low pressure steam (1 - 2 bar)
(ii) nitrogen/inert gas.
I'm trying to figure out the flow rates, so that I can calculate the relief valve sizing -can the relief valve take it if the pipework bursts.
Appreciate your help.
Rgds,
Narseille de Gebeng
#2 Guest_Chemical Weiner_*
  • guestGuests
Posted 12 December 2003 - 12:23 PM
It's just a simple application of the ideal gas law and pipe dimensions. If all you have is pressure drop through the piping, then you might-could use bernoulli's relationship.
#3 mbeychok
mbeychok
  • 364 posts
Posted 12 December 2003 - 04:13 PM
Narseille:
Your question is very poorly explained. If you have to ask how to calculate flow rates, then I would advise you to find an experienced engineer to size that relief valve ... don't try it yourself.
Milton Beychok
#4 ADL
ADL
  • 48 posts
Posted 24 December 2003 - 04:33 PM
I have a software which will ease your calculations. I fyou are interested please contact at: cogim_ir@hotmail.com
